lazerprovo
Feb 14, 2025Aspirant
What can I do Readynas 2304
Hi, I am stuck with this device and readycloud no longer works. I did pay a lot for this though... I hate this brand. Tried to install openmediavault on an external usb, but the device always...
Sandshark
Apr 20, 2025Sensei
I suppose Netgear could have soldered in a USB device for the flash, but I rather doubt it. So, I think that is a DOM.
MlSTRDC
Apr 20, 2025Tutor
Confirmed DOM.
Had my son open it up and take a few photos.
RR2304_OverviewDOM Side 2DOM Side 1RR2304 HD BackplaneDOM OnboardDOM Motherboard Connection
- SandsharkApr 20, 2025Sensei
I can't see your photos till a moderator releases them, but thanks. They'll be of use once I can see them.
While I've never done it, I've read on other forums that all you need to do is remove the DOM and then you'll be able to boot directly to another device without intervention.
- lazerprovoApr 21, 2025Aspirant
I opened the device a couple of months and didnt notice the DOM... I did solder a RAM slot on the motherboard but it was worthless, it wont work. Must be tied to BIOS ROM.
About the DOM... I am pretty sure that TSOP48 chip can be replaced with another high capacity one from a USB with its own controller, or at least using one with a Physon controller. Should try that.
- SandsharkApr 21, 2025Sensei
Yes, but AFAIK, that's only a USB2 device and connector. You'd be better off booting from a hard drive or USB3 device.
As for the memory, it's likely also missing one or more buffers and/or pull up/down resistor packs.
- lazerprovoDec 15, 2025Aspirant
Hi there! Forgot to say I got rid of the DOM and installed OMV on an external USB at the back of the device!
Also I noticed that you can also place a USB inside with a 10 pin header to USB A adapter, but yeah it will go at USB2 speed.
The good thing about the internal DOM is that the chip uses a SLC (single level cell) NAND, you wont be getting anything more reliable than that. I might solder another NAND in the future just for fun. It would be more reliable as the controller sits on the board and not on the monolith external USB NAND.
The pull up/down resistors would be nice to know... there must be another motherboard from another model that uses the other memory socket...
