lazerprovo
Feb 14, 2025Aspirant
What can I do Readynas 2304
Hi, I am stuck with this device and readycloud no longer works. I did pay a lot for this though... I hate this brand. Tried to install openmediavault on an external usb, but the device always...
MlSTRDC
Apr 20, 2025Tutor
Confirmed DOM.
Had my son open it up and take a few photos.
RR2304_OverviewDOM Side 2DOM Side 1RR2304 HD BackplaneDOM OnboardDOM Motherboard Connection
Sandshark
Apr 20, 2025Sensei
I can't see your photos till a moderator releases them, but thanks. They'll be of use once I can see them.
While I've never done it, I've read on other forums that all you need to do is remove the DOM and then you'll be able to boot directly to another device without intervention.
