lazerprovo
Feb 14, 2025Aspirant
What can I do Readynas 2304
Hi, I am stuck with this device and readycloud no longer works. I did pay a lot for this though... I hate this brand. Tried to install openmediavault on an external usb, but the device always...
lazerprovo
Apr 21, 2025Aspirant
I opened the device a couple of months and didnt notice the DOM... I did solder a RAM slot on the motherboard but it was worthless, it wont work. Must be tied to BIOS ROM.
About the DOM... I am pretty sure that TSOP48 chip can be replaced with another high capacity one from a USB with its own controller, or at least using one with a Physon controller. Should try that.
Sandshark
Apr 21, 2025Sensei
Yes, but AFAIK, that's only a USB2 device and connector. You'd be better off booting from a hard drive or USB3 device.
As for the memory, it's likely also missing one or more buffers and/or pull up/down resistor packs.
