leo037's avatar
leo037
Luminary
Aug 18, 2023
What can I do with a 628 PCIe slot? Add an SSD?
Wondering if I can add an NVMe SSD on a PCIe card?
Will it show up in the admin panel?
  • I highly doubt.
    I have a SATA M.2 in the M.2 slot. It does not show up there.
    Most people would think of an graphics card. But it is hard to find one that would fit in the tiny space.
    • leo037's avatar
      leo037
      Luminary
      Did you try manually setting up the drive?
      Video card drivers might be an issue
    • tigerten's avatar
      tigerten
      Luminary
      I mounted it to share.
      The good thing is that it persist through factory reset. After factory reset, you need to recreate the share and mount it, add it to fstab.
      • tigerten's avatar
        tigerten
        Luminary
        I used my m.2 drive to store my local repository. It works perfectly well.
ProSupport for Business
