tYin
May 12, 2022Aspirant
Power Control for POE Slot MS510TX
hello together,
i use the MS510TX to connect the 2 POE industrie camera "
to build a reference system. the camera were powered by the POE Port of MS510TX.
To control the temperature of camera i want to know, if there is a feature to disable the power supply only for the POE slot or the solt can be contrained by power.
if yes, is there a possible to control the slot by commandline?
Any hint will be very thankful!
Best Regards!
Tie
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
- DamianMNETGEAR Moderator
Dear Customer,
Kind Regards,
DamianM
NETGEAR Community
Machen Sie mit!
ProSupport for Business
