strykeroz
Jun 07, 2019Tutor
What is ReadyNAS 214 doing when backup button LED is flashing?
Hi guys
This doesn't appear to be covered in the user manual. But apologies in advance if it's there and I'm missing it.
Today my ReadyNAS214 wasn't presenting an admin page and was showing offline in the ReadyCLOUD client, its power light was on with all 4 drive lights on, but as long as I watched the drive activity light wasn't lit.
Since I couldn't find any info on what that LED pattern meant I cycled the power and it booted fine, and the backup light is now out. There's nothing in the log to indicate something was wrong and there's no email alerts either. It's not half a day since the most recent daily backup to USB and the weekly snapshots were done yesterday.
Is the backup light flashing a sign something was amiss?
Thanks, Geoff
Page 57 of the user manual says this pattern is normal. http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
I'm confused here, since this is the first mention of the backup light flashing. Was it flashing before you rebooted?
StephenB wrote:
strykeroz wrote:Is the backup light flashing a sign something was amiss?
It's the first mention, if you ignore my subject...but I can see how I could have asked that better. :smileywink:
Yes. It was flashing originally, along with the other lights as described and the device appearing offline. Rebooting, the flashing backup button LED was extinguished and there's no hint of what was going on in the logs etc.
Does the backup LED flashing mean anything that might lead to an expanation why this ReadyNAS stops presenting its admin login page and appearing offline?
Thanks, Geoff
- Marc_VNETGEAR Employee Retired
Hi @strykeroz
Usually the backup LED blinks if there's a job running. Do you have any job that you have assigned when the backup button is pushed? Did you notice if you have pushed the button after the reboot? It is also possible that the backup ran before this happened did not complete properly.
We need to check the full logs can you send it through PM? Also, what does the LCD show?
Kindly try pushing the power button 1 time during boot time when the progress bar show up and let me know of the status it showed.
Regards
Thanks for progressing this Marc
I don't have any jobs assigned to the button, and I have not touched the device prior to finding it unresponsive (on booting my PC it showed as offline so that's why I had a look).
There was nothing showing on the LCD at the time, and pressing the power button didn't change this so I cycled the power by removing the plug.
I should add since this happened and I posted, the RN214 is once again functioning fine. It's not the first time it's done this however.
I'll send you the log later tonight.
Cheers, Geoff
