blinke's avatar
blinke
what is the max size
Hello,
I'm trying to find out the maximun size hard drive that I can install to my RN526x unit.
Thanks
Bill
  • There is no known max. An 18 TB drive is on the compatibility list.
    Note Netgear is very sluggish on updating the HCL.  Generally any enterprise or CMR NAS-purposed SATA drives will work (not SAS).  Avoid WD Reds, as they are SMR - but WD Red Plus (as well as Seagate IronWolf) are fine.
  • StephenB's avatar
ProSupport for Business
