Richard1982's avatar
Richard1982
What Ready Nas
I picked up this readynas duo from a friend who owed me some money. I was going to drop it on ebay after testing it but I have had nothing but issues with it. I dropped a drive in it and waited for...
  • StephenB's avatar
    Feb 13, 2018
    wrote:
    ok, next question is am I stuck at firmware version 4 with no samba v2/3 ?
    Yes.  OS 5.x also is SMB 1.0.
    There is experimental support for SMB 2.0 in the Samba version your Duo  uses, but I don't know how reliable that is.  To enable it you'd have to first enable SSH by installing an add-on, and then log into the linux shell and tinker with a configuration file.  Note that the OS is installed on the disks, so anyone installing new disks would need to repeat this procedure.
    My own Duo v1 is used only to back up bigger/faster NAS, and I only have rsync enabled on it.
    As far as performance goes, SMB speed is ~15-20 MB/s on a gigabit network.  Disk size is limited to 2 TB, because GPT formatting is not supported.  This model was replaced by the v2 in November, 2011.
ProSupport for Business
