chris2003
Oct 26, 2026Follower
Where can I buy or get hard drive trays for a ReadyNAS RN104 (RN10400)?
Hi everyone, I recently picked up a ReadyNAS RN104 (RN10400) second-hand, but unfortunately, it came completely bare without any hard drive trays/sleds. Since this model has been discontinued for a w...
- Oct 26, 2026
chris2003 wrote:
https://www.thingiverse.com/thing:4776644
Is this compatible?It looks like it might be. You'd need to 3d print it to find out for sure.
Oct 26, 2026Guru - Experienced User
Very unfortunate when sellers do this.
All OS-6 desktops use the same trays (RN10x, RN2xx, RN3xx, RN42x, RN5xx, RN62x) - which might help you search.
The older Duo, NV+, Ultra, and Pro desktop trays will also fit (though they aren't as good, and the ones with round buttons are prone to stick). So you could look for one of those models for parts.
chris2003
Is this compatible?
