chris2003
Oct 26, 2026Follower
Where can I buy or get hard drive trays for a ReadyNAS RN104 (RN10400)?
Hi everyone, I recently picked up a ReadyNAS RN104 (RN10400) second-hand, but unfortunately, it came completely bare without any hard drive trays/sleds. Since this model has been discontinued for a w...
- Oct 26, 2026
chris2003 wrote:
https://www.thingiverse.com/thing:4776644
Is this compatible?It looks like it might be. You'd need to 3d print it to find out for sure.
Oct 26, 2026Guru - Experienced User
chris2003 wrote:https://www.thingiverse.com/thing:4776644
Is this compatible?
- SandsharkOct 26, 2026Sensei
Replacement trays were never widely available and were quite expensive where they were sold (>$50 each). Unfortunately, businesses get lazy and remove NAS drives for destruction without removing them from the trays. They have no idea how much that devalues a ReadyNAS. I do hope you didn't pay a lot for that 104, because the value of one with trays is not a lot more than the typical cost of 4 trays.
The issue I see with that one is that it attempts to clone the second-generation legacy tray but the hook that holds the tray in is plastic instead of metal. I can't see that lasting. Some similar ones show making that part from metal. Cloning the newer one, which has a much wider plastic lip that holds it in, would have been a lot smarter. There used to be a seller on eBay that sold 3d printed tray replacements that didn't even try to have a latch, but I no longer see a listing for them. Unless you are moving the NAS with drives installed (a really bad idea), you shouldn't need latches.
