Mrk74
May 11, 2018Aspirant
Which advantages does upgrading ReadyNAS Ultra 2 to OS6 have?
So I have 2 ReadyNAS Ultra 2 with 2x 2Tb disks in it.
I've seen that the Ultra 2 can be upgraded (without support) to OS6.
Which advantages does upgrading to OS6 have? Is it worth the ris...
Mrk74
May 14, 2018Aspirant
Thanks for the fast reply StephenB!
Another question:
- When I update the ReadyNAS Ultra 2 to the latest OS6 firmware, will automatic OS6 updates work?
May 14, 2018Guru - Experienced User
Mrk74 wrote:
Another question:
The system will find the updates, and you have a few options here (beta, latest, and stable). Also, Netgear does push hot-fixes silently.
Of course if you are using a static IP address configuration, you do need to make sure there is at least one DNS server configured.
