Icarus
Aug 07, 2013Aspirant
Which APc model is suitable for ReadnasRDN2110
Hi All. I have a ReadyNas Nd 2110. Want to protect it from mains power loss Looking for a suitable smart UPS . Having trouble identifying the correct UPS model. If possible I want the UPS to shut...
mdgm-ntgr
Aug 07, 2013NETGEAR Employee Retired
Some UPS units would use power cables like the ones used to connect a monitor to power via your PC for connecting your devices (e.g. the Duo) to the UPS. If you get one of those they may give you a few of the cables and get you to swap that with the cable that connects to your Duo power brick at the moment which would then be used to connect the UPS to the power outlet on the wall.
