deejay_1956
Aug 25, 2011Aspirant
Which drives to buy?
Hi, I've just bought a readynas 4000 ultra ( NO PLUS) and I have difficulties to select which drives I should buy. I don't want to spend more then 100 -120$ per disk. When checking the HCL, I noti...
deejay_1956
TX PapaBear
You're talking about the Samsung HD204UI .
Is this then an eco green disk?
I also have a look into the Hitachi ones.
The Seagate referring my post has a speed of 6Gb/s. Wondering if the Ultra can handele this on his Sata 2 interface?
Thanks so far.
Thanks so far.
