William10a
Mar 08, 2017Master
Which nas sever is right for me
Which nas sever would you use for the r8500 router as windows back up and may be movies if possible the only nas sever I used fefore was a freenas made from a old computer with ide hard drives slow a...
Mar 13, 2017Guru - Experienced User
Sandshark wrote:
For one to a few users, a 214 would be a good choice.
I agree.
RAID-5 performance (large file transfers) is ~100 MB/sec on a gigabit network.
jak0lantash
Mar 13, 2017Mentor
http://www.downloads.netgear.com/files/GDC/R8500/R8500_UM_4jan2016.pdf
page 65 might be of interested to you as well. You can create an aggregate on the R8500 to the RN214.
- StephenBMar 14, 2017Guru - Experienced User
Yes. Though most home users don't have enough simultaneous users to guarantee a performance improvement with LACP bonding. With 2 users, there's only a 25% chance that both the uplinks and downlinks will be optimal.
So if you need the R8500 LAN port for something else, just use one NIC. But if the port is free anyway, you might as well take advantage of the LACP support.
- jak0lantashMar 14, 2017Mentor
StephenB wrote:
if the port is free anyway, you might as well take advantage of the LACP support.(thumbs up)
No content to show
