stianw
Apr 19, 2012Aspirant
Which RAID when backing up from local to remote readynas?
Hello readyNAS wizards! I'm just about to buy 2 ReadyNAS Ultra 2 with either 1X2TB or 2X2TB in each. I have a couple of brainteaser (perhaps) questions: One will be at my place, the other at my...
PapaBear1
Apr 21, 2012Apprentice
If you are going to operating from the files on the NAS, you may want to use a more descriptive name such as oper rather than backup1. Use the default backup for the remote NAS, then back up your operational files (oper) to the backup share on the remote NAS. That would give you three shares, the default backup and media and oper (or operational if you prefer, I have an old habit of short folder names).
Just be sure to not put your photos in the default photo folder under the default share media. It would not be backed up under your design. I would create a photo folder that is under a share that is backed up. (my photos are under the media share, but it is rsynched to the media share on the second NAS).
