barryd
Jul 15, 2015Aspirant
Which Ready NAS do I need please?
Hello. I have installed a handful of ReadyNAS products over the years and they have been very good. I have a client who has the following requirements to serve up to 12 PC's 4TB usable storage....
RX
Jul 15, 2015Luminary
barryd wrote: Thanks. Is there a 2 bay model that comes with 2 x 4tb drives? If not is it a case of installing 2 x 4tb drives into a diskless 2 bay model and thats it? Will the default config be Raid 1 and therefore if you insert 2 x 4TB drives one will be mirrored automatically with 8TB total capacity with 4TB for data?
I believe there is no model that comes with 2x4TB drives. You may check it on this link below:
http://netgear.com/business/products/st ... tab-models
However, it is possible that you start with a diskless 2-bay model (let say an RN312) then set it up with 2x4TB drives in it. The default config will be XRAID-RAID1 since there are 2x4TB drives in it. It means that the data is mirrored to each drive resulting to allow one-drive failure. Since its XRAID, if you decide to replace a faulty drive or replace one of the drives with a higher capacity, then you will just simply hot-swap it and it should proceed with the resync process automatically.
You may check the compatible drives for the ReadyNAS OS 6 models here on this link below:
http://kb.netgear.com/app/answers/detail/a_id/20641
