Campus's avatar
Campus
Luminary
May 04, 2023
Which SFP+ modules are compatible with 4312
Is there any recommendation which SFP+ modules are supported by the 4312S out of the box? Does it have to be a Netgear module or could it be any manufacturer?
1 Reply
  • NiveditaP's avatar
    NiveditaP
    NETGEAR Employee Retired
    Hello Campus
    For the 4312 model of ReadyNAS, we would suggest AXM764 and AXM765. It is a Netgear manufacturer and we could find the 10Gbps LAN Optical SFP+ only in the datasheet of the NAS device model.
    Since Netgear manufactures this it would be a better option to pick any one of these two (AXM764, AXM765 ) for better compatibility.
    Furthermore, it is not model specified and it is SFP+ module specified. So hope this will help you and you can choose according to your need,
    If your issue is resolved please close the thread by clicking "Accept as solution".
    Have a lovely day,
    NiveditaPa
    Netgear Team
ProSupport for Business
