norm470
Dec 11, 2011Aspirant
Which should I get
I am close to buying my first nas I just don't know which one.What I am going to use it for is mainly for backup my pictures and videos and stream them to my tv. Alot of my videos are blue ray iso fi...
Jjnsgy
Invader980-
Are you (plex) transcoding your videos from bluray to some lower def format or streaming the ripped format directly? It was my impression from other forums that the dual core of the pro 6 is the best at transcoding. The difference in price if the disk less systems is enought to buy a drive or 2.
Thanks.
Thanks.
No content to show
