kevinfor2014
Mar 24, 2017Guide
Which unit to buy RN628X vs RN528X & RR4312X ?
Trying to decide between these 3 models ... does the RN528x have enough CPU /ram power for 4K Transcoding & PLEX Server? as it seems to have less RAM/CPU whereas the RR4312X /RN628X both have similar...
- Mar 29, 2017
If you're wanting to do real-time transcoding you should go with the RN628X. It depends on various factors about the video how well it would work.
If just needing to transcode for e.g. syncing to a tablet (a Plex Pass feature) then it taking longer is not as big an issue.If you just need to stream (not transcode) then it shouldn't matter which you go with.
kevinfor2014
Mar 29, 2017Guide
is the RN528X CPU/RAM Fast enough for 4K HD Encoding H.264 /Streaming PLEX - or will it just take longer
mdgm-ntgr
Mar 29, 2017NETGEAR Employee Retired
