rejoyce1
Jul 23, 2012Aspirant
which UPS to buy?
Hi I have a ReadyNAS Duo with 2 x 2TB Seagate barracudas. I am interested in adding UPS as I've had a few outages for various reasons, I am just looking for a low cost option that will add another...
PapaBear1
Jul 28, 2012Apprentice
If you have not already done the trial, StephenB came up with a good test. Shut down the NAS normally and plug it directly into the mains and then restart. With the UPS cable connected to the NAS is should detect the UPS. Pull the plug on the UPS and when it gets low, it should shut down the NAS normally. If it does not, there is no sudden shut down of the NAS since it is on a separate power source.
If it works, you can then plug the NAS back into the UPS and plug the UPS back into the mains. After the UPS has built up a bit, you then then restart the NAS.
