Arneil's avatar
Arneil
WINDOWS 10 - ReadyNAS Remote not connecting
I have windows 10. I bought a pre owned duo v2. I have 2 seagate 2tb drives. The drive is installed and I can browse the drives via netgear dash board. I just need to know if I can access the drive v...
  • Arneil's avatar
    Arneil
    Sep 19, 2016
    Thank you for the fast response, and thank you for the solution!
ProSupport for Business
