enkrypt3d
Aug 04, 2019Tutor
Writes fall to zero bytes after a few seconds
Every time I try to copy a file to the NAS, it starts out fine and then the writes fall to 0 bytes and then eventually errors out... on the latest firmware. A reboot seems to fix the issue for a whil...
Retired_Member
Aug 05, 2019Hi enkrypt3d , try disabling ipv6 in the nic config. Kind regards
