enkrypt3d
Aug 04, 2019Tutor
Writes fall to zero bytes after a few seconds
Every time I try to copy a file to the NAS, it starts out fine and then the writes fall to 0 bytes and then eventually errors out... on the latest firmware. A reboot seems to fix the issue for a whil...
crane10970
Feb 16, 2025Aspirant
Yes the resource has been mongodb. It is the most $#% and resources consuming database possible. Altough in some cases, programs or apps dont support any other db than mongo. It stalls system resources in some moments but pretty / ugly often. Havent invented with my research what it does. Planning to install it on SSD, instead of harddrive as usual. Could change it. Hopefully. It is also one of the most drive space consuming db. 🙂
