netjazzer
Feb 09, 2014Aspirant
Wrong checksum by updating to Raidiator 4.1.13 on Duo v1
Hello, i try to update my READYNAS DUO v1 (2110) to new Raidiator 4.1.13 by a local update. therefore i download the RAIDiator-V4.1.13 with different browsers and on different computers (Mac OS X a...
Feb 11, 2014Guru - Experienced User
Sorry, I am a bit confused on what you are saying. Normally you install the sparc add-on from here: http://www.readynas.com/?p=4203 Then you access the NAS using a tool like putty, logging in as "root" and using the NAS admin.
netjazzer wrote: ...but there is no error message when i tried to install enabled-ssh, it only doesn't work. there is no sshd after the reboot after installing...
Perhaps try deleting the log files via frontview, and see if that helps?
