Zacki
Dec 13, 2015Aspirant
wrong disk size at ready nas duo
Hi, I have a old Ready Nas Duo with RAIDiator 4.1.14. I had 2x500 GB as X-Raid. I changed to new 2 x WD30EZRX (3 TB). After Update both are redundant and everything is well. But free space wa...
Zacki
Hi Stephen,
thank you for your fast answer. Any chance to change from 741 GB to 2 TB with this disk? Why choose the ready nas 741 instead of 2 TB?
best regards Zacki
mdgm-ntgr
Dec 13, 2015NETGEAR Employee Retired
No. The Duo v1 does not support GPT.
3TB disks being seen as having 741GB capacity is a known problem that results from using them in a system in which GPT is not supported.
The Duo v1 was the last of the Sparc models to be released and was released back in 2008. It's the 2-bay version of a product released back in February 2006. The hardware is about 10 years old now.
All our newer models have GPT support.
- ZackiDec 13, 2015Aspirant
Hi mdgm,
thanks for support.
Ok, then I have a newer version, because on the bottom I found: ReadyNas Duo RND2150 v2. This is the second version, correct?
Best regards
Zacki
- mdgm-ntgrDec 13, 2015NETGEAR Employee Retired
No, you are running 4.1.14 so you must have a v1. The firmware for the v1 will only run on the v1 not the v2 and vice versa.
You have a Duo v1 hardware revision 2 that came pre-installed with one 500GB disk. See http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The Duo v2 (runs RAIDiator-arm 5.3.x) has always had GPT support.- ZackiDec 14, 2015Aspirant
Thank you - now it is clear!
best regards
Zacki
