cwietholt
Feb 16, 2013Aspirant
X-RAID2 and X-RAID compatibility
My old ReadyNas NV+ just died. It has been running permanently for the last 4 years or so. I had it shutdown to move it to a new location, and now it is not turning on anymore. I assume that the power...
mdgm-ntgr
Feb 16, 2013NETGEAR Employee Retired
The RAID format is different so know you cannot migrate your disks across to the NV+ v2.
If you get a replacement NV+ to migrate your array across you would need to buy another v1: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
