supahfly
May 31, 2013Aspirant
X-RAID2 compatible with other boxes?
Hi I am sure this question has been asked before, but I did not know how to properly look for the answer so here it goes: The whole purpose of having RAID is to have a redundancy feature for yo...
mdgm-ntgr
May 31, 2013NETGEAR Employee Retired
The proprietary stuff in X-RAID2 are the scripts used to automate expansion. That's all.
Using free utilities you can easily mount the data volume after connecting your disks to a standard Linux box, providing all your disks are fine (or one less the number in your array if it is redundant).
