supahfly
May 31, 2013Aspirant
X-RAID2 compatible with other boxes?
Hi I am sure this question has been asked before, but I did not know how to properly look for the answer so here it goes: The whole purpose of having RAID is to have a redundancy feature for yo...
Jul 10, 2013Guru - Experienced User
No. All you can do is a factory reset, and restore the data from backup. If you do that, and select flexraid than you could create 2 RAID-1 volumes on the NAS. Note you could start with 1 RAID-1 volume and add the second later on.
supahfly wrote: Is there a way to go from Xraid2 to RAID1 ( I now have 3*2TB discs inserted...
There's a short window (~5 minutes) after you start the reset when you can select flexraid. You do that with RAIDar.
