NTake
Feb 15, 2022Aspirant
X-RAID2 "Dead", even though still fully-accessible
I have a ReadyNAS Ultra 4 Plus that I use primarily for storing music. It has four Seagate IronWolf drives (3x3TB + 1x4TB) that show green buttons. The volume is also completely accessible, readabl...
- Feb 16, 2022
The steps are
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you so want to update the bios it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
Feb 15, 2022Guru - Experienced User
NTake wrote:
I have a ReadyNAS Ultra 4 Plus that I use primarily for storing music. It has four Seagate IronWolf drives (3x3TB + 1x4TB) that show green buttons. The volume is also completely accessible, readable by my Sonos system as well as desktop Windows computer. However, when checking the Volume Settings-->RAID Configuration, the Status shows "Dead. This volume is no longer available.". Disk space also shows "0 MB (0%) of 0 MB used".
Is this just a glitch or something I need to be concerned about? If a glitch, any way to rectify it?
I don't know what is going on, but I do recommend that you make sure you have an up-to-date backup.
After that is taken care of, I suggest downloading the log zip file, and looking for RAID (mdadm) and file system, and disk errors.
Sandshark
Feb 15, 2022Sensei
I had a NAS that did that, and I found it was because some of the drives were slower to spin up than others. But I had a 3 + 3 of two drive types, and you have but one that's differtent. And it also typically "kicked out" one of the drives from the volume. I think there is some kind of bug that causes a volume to be marked dead, even for a temporary condition, the NAS still reports it is, though it isn't any longer.
BTW, I upgraded that NAS top OS6 abnd the problem went away. Given other issues are begining to arise due to the age of OS4.x and specific protocols being removed from PC's, you may want to consider upgrading to OS6 before the next shoe falls.
