sbrause
Mar 03, 2009Aspirant
XRAID-2 Hot Spare or Expansion with FlexRaid
I've seen a few messages a year old regarding hot spare support on X-RAID. I would really like to see hot spare support on the ReadyNAS pro with XRAID2. I know there is auto expansion to consider bu...
chirpa
Mar 16, 2009Luminary
chirpa wrote:
Enhanced X-RAID2 to support dual-redundancy, allowing for protection from 2 disk failure while maintaining the flexibility of X-RAID2 auto-expansion. To use X-RAID2 in dual-redundancy mode, you will need to backup your data and restore after performing a factory default to set the ReadyNAS in dual-redundancy mode. When you request a factory default and reboot, there’s a 10-minute window where RAIDar will allow you to select the RAID mode. At this time, select X-RAID2 with dual-redundancy option, and you’re good to go. You will need a minimum of 4 disks to see this option, and you will need the RAIDar 4.1.5 release supporting this.
