__m_m_
Dec 31, 2011Aspirant
xref model numbers + names in FAQ
Is there a cross-reference of the model names and model numbers anywhere? I can't find anything in the FAQ or the site. Surely these should be documented, and clearly visible from the "Products" t...
mdgm-ntgr
Dec 31, 2011NETGEAR Employee Retired
Here's a list of the NetGear desktop ReadyNAS models (note for e.g. RND4000 if you replace the three zeros e.g. to get RND4250 you will get the RND4000 but with 2x500GB drives installed, where an appendix e.g. -100 is not shown in the list you can assume it is currently -100)
Discontinued:
RND2000-100 - Duo v1
RND4000-100 - NV+ v1
RNDX4000 - NVX
RNDX400E - NVX Pioneer
RNDP6000-100 Pro Business Edition
RNDP600E-100 Pro Pioneer Edition
Current:
RND2000-200 - Duo v2
RND4000-200 - NV+ v2
RNDU2000 - Ultra 2
RNDU4000 - Ultra 4
RNDU6000 - Ultra 6
RNDP200U - Ultra 2 Plus
RNDP400U - Ultra 4 Plus
RNDP600U-200 - Ultra 6 Plus
RNDP2000 - Pro 2
RNDP4000 - Pro 4
RNDP6000-200 - Pro 6
Welcome to the forum!
The RND2000 v2 is not a mislabelling but is a bit confusing. It would represent a small change in the hardware of the product. As model number was kept the same, the change(s) must have been pretty minor.
Discontinued:
RNDX4000 - NVX
Current:
RNDU2000 - Ultra 2
RNDU4000 - Ultra 4
RNDU6000 - Ultra 6
RNDP2000 - Pro 2
RNDP4000 - Pro 4
