__m_m_
Dec 31, 2011Aspirant
xref model numbers + names in FAQ
Is there a cross-reference of the model names and model numbers anywhere? I can't find anything in the FAQ or the site. Surely these should be documented, and clearly visible from the "Products" t...
__m_m_
Dear Netgear,
I'd still like you to provide a comprehensive and canonical cross-reference of the model names and numbers...
and it'd be good to have a categorical answer on this
thanks,
^^m=m-
^^m=m- wrote: They could go under the Products tab, in the product comparison chart, in the FAQ... please, please, *somewhere*.
^^m=m- wrote:
Another problem:
I bought some sparc Duos, and the sticker on bottom of case reads
ReadyNAS Duo RND2000 v2
The packaging gave RND2000-100.
So, query two - is that "RND2000 v2" a mislabelling?
Or just a v2 of the RND2000 sparc product, quite distinct from the "Duo v2" ARM product line?
thanks,
^^m=m-
