willo
Dec 09, 2011Aspirant
Accessing the ELC data share for LAN only users
A little clarification required please I have a site of say 50 users and of these the 5 managers need access to their data via Egnyte and the OLC Software. This is all setup beautifully but I'd lik...
JohnnyEgnyte
Hi Mark,
Yes, you can create one "LanUser" for the 45 employees. Although because they are logging in with the same credentials, they will all have the same permission level and see the same files. If that is okay, then yes, what you suggested will work.
~ Johnny
~ Johnny
