GarthS
Feb 18, 2018Aspirant
apt-get install libio-socket-ssl-perl fails
I am trying to carry out an apt-get update and apt-get install libio-socket-ssl-perl on my Readynas duo v2 which has 5.3.13 s/w. I have attached a word doc of the install log which shows the errors ...
Feb 19, 2018Guru - Experienced User
GarthS wrote:
The NAS is running 5.3.13 s/w so Duo V2 is correct?
Yes.
Sandshark
Feb 20, 2018Sensei
My bad, I thought OS5.x was lenny (Debian 5), but I guess it's squeeze (debian 6). Try adding these:
deb http://archive.debian.org/debian/ squeeze contrib main non-free deb-src http://archive.debian.org/debian/ squeeze contrib main non-free
- GarthSFeb 21, 2018Aspirant
I added the two lines and things have now improved but I still get error messages and W failed to fetch, when i do the Update and Install. The improvement is that if I now do an install again it reports -
'libio-socket-ssl-perl is already the newest version' which sounds good but it does not seem to working.with my application. What checks can I do to verify it is now installed correctly? Attached is a pdf log file of the update/install shiowing the errors etc.
- SandsharkFeb 22, 2018Sensei
Obviously there are some repositories that can be deleted to clean things up, but they should be ignored, anyway. But something must still be missing (needs to be re-directed to archives) See if /var/log/apt/history.log or /var/log/apt/term.log give any more information.
- watsonmMar 22, 2018Aspirant
many thanks..... been trying all the suggestions to get IO::Socket::SSL installed and this one worked for me...
sorry meant to include original.
Sandsharkwrote:Try adding these:
many thanks..... been trying all the suggestions to get IO::socket::SSL installed and this one worked for me...
