Swoofah
May 04, 2011Tutor
Automatic x86 RSS and Cookies configuration
So yes. Ive searched the forum and interwebs far and wide (not so easy when the program is called automatic , and does something automatically, by the way -.-) and found next to nothing on this iss...
Trial_Master
May 13, 2011Aspirant
Hi Stefan
We had the same issue with private tracker cookies when testing your addon so as an alternative had to change 'use transmission' value to no and enable watch directory.
That worked fine but I noticed SP made a x86 addon and his worked with private tracker cookies and I have above value set to yes. I must admit I haven't tried yours or looked into the original issue since it currently works fine I left things as they were.
I haven't had to configure anything for the cookies to work the 'use-transmission' feature caused this issue with your addon but not SP? I know nothing about these things it's just my experiences with both versions.
SP addon viewtopic.php?f=36&t=39157
PS I should note checking my SP configuration file there is no cookie fields just the private tracker URL field.
