Swoofah
May 04, 2011Tutor
Automatic x86 RSS and Cookies configuration
So yes. Ive searched the forum and interwebs far and wide (not so easy when the program is called automatic , and does something automatically, by the way -.-) and found next to nothing on this iss...
Swoofah
May 20, 2011Tutor
Thanks for the reply Trial_Master, but as WhoCares? said; the question here is what to do when you got the addon, not what to use.
The use-transmission parameter is irrelevant at this point, because i have'nt got the torrentfile yet.
So please; how do one set up the configuration? An example of a private tracker setup would be appreciated!
Or is it time to move away from the Automatic + Transmission setup and just use the uTorrent-addon? Does it support the use of private-trackers now?
