matyhaty's avatar
matyhaty
Follower
Nov 10, 2013
Bit Torrent Sync (99% done?)
Hi All
I know this seems like a 'how hard can it be' but could this be made into a add on with a few minutes of work from someone who knows how:?
Below are my logs to install bit torrent, and getting it running at boot. Surely this is easy to port to a proper add on??
Installed on ReadyNAS NV+ v2 (ARM)
1. Download Linux ARM compressed binary btsync_arm.tar.gz
2. scp file to root directory on ReadyNAS.
3. ssh to ReadyNAS, uncompress and untar the binary.
4. Load BTSync by typing ./btsync at command line.
6. Accessed the GUI via http://<ReadyNAS IP>:8888/gui/
For the startup on boot:
The best way is probably to treat it as an addon. You can simply add a line in /etc/frontview/addons/addons.conf for your program. Follow the syntax of the SlimServer and DAAP addons, which is:
CODE:
SERVICE_NAME!!Friendly_Name!!Version!!Startup_command!!Stop_command
After that, add a line in /etc/default/services with
CODE:
SERVICE_NAME=1
e.g.
BTSYNC!!Bit Torrent Sync!!/btsync!!/btsync
ProSupport for Business
