scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
chirpa
Mar 27, 2008Luminary
With a few tweaks it could work in Opera as well. Opera supports greasemonkey scripts internally.
Main part that needs tweaking is the prompt for the server address, that won't do popup, would have to hard code the address in the .js file before hand.
