scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
scep
Jun 09, 2008Aspirant
OK, it will now only show up in the main window. No more copies in iframes/frames.
Any other suggestions on how i can improve this, im open to ideas?
sphardy wrote: Hello scep
First - thanks for a great add on. Have been using since your first published it and it has worked very well.
But... I have a problem to report with this latest update.
It does work as advertised, but I have found that I get spurious copies of the monitor appearing as I browse the web. Take for example http://news.bbc.co.uk - here I get the monitor popping up in the top right corner above the "Other Top Stories" section in addition to the standard bottom right corner. On other pages I have seen the monitor appear multiple times on the one page.
Hope you can take a look at this
///P
