scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
scep
Jun 14, 2008Aspirant
I can work on that, sure. and the order is whatever the readynas happens to send it out it. I think its the order they were added. I never put in a sorting command.
Binks wrote: I've got a feature request, if it isn't too much trouble.
Could you set it up so left-click sends the torrent file to the ReadyNAS, and right-click brings up the normal right-click menu?
That way, if for some reason I want to download the torrent to my system, or copy the location of the torrent, I can.
Thanks!
Oh, and one question - what order are the bottom torrent indicators arranged in? It doesn't look like it's alphabetical or by size. I'm just curious; that's all :)
