scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
Binks
Jul 01, 2008Aspirant
Queonda wrote: Ok, maybe not a problem with your program.
But I had utorrent on this computer. Now I wanted to try to auto link and try bit torrent on the nas. I installed your monkey for firefox and all looks good per your instruction.
Now If I click the torrent, it's still associated with utorrent. How do I make it be associated with greasemonkey and your script, intead of utorrent?
I tried to manually copy the torrent link location into the ready nas torrent browswer but doesn't link. I had to download the link to the desktop then upload to bittorrent ready nas for it to work.
Thanks ahead for your help.
That's really quite bizarre - I did almost the exact same thing as you, with no issues at all. I didn't have to do anything with file associations - the script seems to "grab" the link before anything else happens.
OH! Actually, some places do funny things with their torrents - for example, tvtorrents.com torrent links don't work, but they do some strange things with their URLs, so I sort of expected to have problems there.
Do you see the +NAS image in green next to your target links? What if you just tried a random torrent off of thepiratebay.org? Those have always worked wonderfully for me.
As I understand it, all this code does is the equivalent of sending the link to the interface, just the same as you'd do it manually, so if manually entering a .torrent link doesn't work then I expect this script won't either.
