scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
Binks
Aug 19, 2008Aspirant
Lover wrote: This would be also great if it would be an addon program for Frontview and also would work under Windows Internet Explorer.
Thank you.
That's way outside the scope of this particular project - this script just works with Greasemonkey, which is just for Firefox.
The script simply wouldn't work conceptually as an addon in Frontview, since it has to modify each webpage you visit, and that can only be done locally - from your own computer.
