scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
Binks
Aug 19, 2008Aspirant
jaysin436 wrote: I'd like to 2nd the request for the ability to hide the monitor. I often browse and search via my EEE PC and with it's small screen, pixels are at a premium. Hiding the monitor would be nice a feature.
You can just right-click on the monkey head at the bottom of the screen, then select "ReadyNas Torrent Linker & Monitor". This should remove the checkmark from in front of it. That'll disable the script, and once you reload the page the monitor will be gone. You should just have to right-click and re enable it when you want it back. This might be an acceptable stopgap measure for you.
