scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
markdibley
May 05, 2010Aspirant
Hello
I don't think anyone has mentioned using the autolinker on Chrome.
I have tried to get the autolinker working on Chrome, first by downloading Greasemetal (which doesn't work) and then by installing the autolinker as an extension (as Chrome appears to support userscripts without greasemonkey/metal).
The script installs fine, but there doesn't appear to be any functionality (links aren't highlighted, nothing added to the right-click menu, torrent files still associated with uTorrent).
Does anyone know if this script will work on Chrome or is it possible to make it work with some modifications?
