scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
Rushian
May 30, 2011Aspirant
Make sure there is no trailing slash / at the end of the ReadyNAS address in the script config.
At first I had a / in there and it didn't work for me either. I then took it out, and it started to work perfectly for me, even using Firefox 4.01. :)
