JabbaTheHutt
Apr 18, 2014Tutor
Bittorrent Sync for ReadyNAS OS 6
http://blog.bittorrent.com/2014/04/15/b ... orage-nas/ There is a native BitTorrent Sync app available now. Install from the Available Apps tab or install manually http://apps.readynas.com/pages...
kuk
May 17, 2014Aspirant
Sorry it's me again:
i installed your version from your dropbox, but nothing changed so far therefore my initial problem still persists:
on my 104 erything seems to work fine, except for the fact that the preferences and device name aren't kept after a reboot.
Especially it seems that the listening port is CHANGED (not even only kept) or varies after every boot.
Do you know this behavior since it is very annoying to edit this settings after every reboot (or to reconfigure my firewall).
Thx
Thx
