ansfrat
Mar 05, 2010Aspirant
BitTorrent will not seed/upload
Hi all.
On my Readynas Duo I can can download fine with a good speed but it will not seed the torrents. I have checked that port is ok and set port forwarding to the units ip both udp and tcp. What can cause it not to seed the files?
- NarkAspirantIs he not seeding at all or is he only seeding when you're downloading?
- ansfratAspirantNot seeding at all.
- ZmurfenAspirantwaking up the thread....
Having same problem....won't seed/upload.
Down is ok!
Did you resolve it, or any one got a clue? - ketan324AspirantI have the same problem. I confirmed port forwarding is setup correctly on my router. My Windows 7 laptop has no problem getting to 500k-1Mb/s upload speeds, HOWEVER BitTorrent on the ReadyNAS DUO box is super slow. In fact the upload doesn't appear to be sustained over a period of time. The upload will start/stop randomly, and when it is running I'm lucky if I get more than 30Kb/s upload speed. Does anybody have suggestions or fixes for this issue? Are their other clients I can test out on the NAS box? Btw, download is not an issue at all, I average around 1Mb/s most of the time. Thanks.
- johnrogerAspirantDid u get it to work properly?
I just bought a ReadyNAS Ultra, and having problems getting uploadspeed from "private" torrents :(
