depasseg
Feb 06, 2012Aspirant
Cacti and PHP installation failures
I'm pulling my hair out trying to get Cacti (PRO-Cacti_1.9) running on a fresh 4.2.20-T28 Pro 6. I'm getting a "Problem installing PHP 5 Library" pop up message. Then frontview can't be accessed ...
Ionitor
I seem to remember the issue being that the Cacti add-on downloads a specific version of PHP and installs it, regardless of whether you have PHP installed or not. And there is a problem with that package on current firmware -- I want to say it was a broken dependency, but I don't remember. I do know that I ended up manually pulling apart the Cacti add-on and altering the installation script to finally get it installed, and that the PHP issue was not the only problem. Unfortunately, I completely failed to take notes on what I did.
