depasseg
Feb 06, 2012Aspirant
Cacti and PHP installation failures
I'm pulling my hair out trying to get Cacti (PRO-Cacti_1.9) running on a fresh 4.2.20-T28 Pro 6. I'm getting a "Problem installing PHP 5 Library" pop up message. Then frontview can't be accessed ...
depasseg
Feb 07, 2012Aspirant
Thanks for the confirmation that the Cacti plugin was broken for you as well. I'll try to dig into the package and see if I can make the same mods.
