wvkreg
May 07, 2012Aspirant
cacti and webinterface gone
My webinterface is unaccesible after upgrading tot version 4.20 and installing Cacti 1.8 from Netgear Readynas site. How can I restore the webinterface, in my case: https://192.168.1.150/admin. I t...
InTheShires
May 07, 2012Tutor
wvkreg wrote: My webinterface is unaccesible after upgrading tot version 4.20 and installing Cacti 1.8 from Netgear Readynas site.
I tried OS reinstall via boot menu, but the firmware update seems to reinstall 4.20 and not 4.17. Pls help!
I also uninstalled Cacti via command line, but still no webinterface,
regards
wim
I had similar problems with Cacti. My solution was to re-install the PHP addon, in fact I had to do it a couple of times to get FV back. (I also lost PHPMyAdmin, which needed a re-install as well.)
You could try an Apache restart via CLI, but for me that wasn't enough. I had to fiddle with a few things.
- May 25, 2022Retired_Member
